Installing Webasto or similiar
Has anyone installed Webasto or similiar heater to DF800?
Recommendations for installation location?
Re: Installing Webasto or similar
I think the main problem with Webasto or similar on a DF800 is the small battery bank and small regeneration capability. A Webasto uses about 2-8 amps per hour in operation, and you're limited to an outboard motor which generates (at most) 6 amps, and whatever solar you can mount. If you add solar you will also add at least one more battery, and you will need a diesel tank, and the project spirals upward in cost and weight.Vepo wrote:Has anyone installed Webasto or similar heater to DF800?
I think you would do better with a drip heater such as Refleks or similar. Or a LP gas heater. Less power required, simpler installation.
Webasto 2000ST consumes 14-29 W/h in operation which is far less you described.Double Horizon wrote:I think the main problem with Webasto or similar on a DF800 is the small battery bank and small regeneration capability. A Webasto uses about 2-8 amps per hour in operation, and you're limited to an outboard motor which generates (at most) 6 amps, and whatever solar you can mount. If you add solar you will also add at least one more battery, and you will need a diesel tank, and the project spirals upward in cost and weight.Vepo wrote:Has anyone installed Webasto or similar heater to DF800?
Yet it will be the largest consumer before refrigerator and plotter so using it a lot would lead to some battery capasity problems. We'll see.
I have default DF800 solar panel (around 30W I think).
I don't see is as a problem to install an external ~15l diesel tank for it.
This will be installed to be used quite rarely when it's cold & wet & totally worth it (and the battery can take it).
Huge advantage in Webasto is that it actually dries the cabin air.
So I will be installing the Webasto (already bought one). If anyone has done a similiar installation let me know how you did it
Sorry double post
adrianbell
- Your Country: England,south coast
heating system df800
I have fitted a propex gas heater system. I did research and this has the lowest electrical consumption and it has thermostat in cabin. the diesel sytems use too much current. I also fitted a self draining gas locker under cockpit seat at the same time, some boats have gas already which is even better. The system consumes very little gas. I mounted the boiler under cockpit floor on a bracket, if you take out the large drawer from inside there is plenty of space to fit. propex make a marine system and it is a warm air system with small boiler, inlet and exhaust external so very safe and only one gas connection outside of gas locker.
i run the boat on one battery with one solar panel and and additional plug in solar panel for summer when i plug in a waeco fridge.
As a back up my honda outboard produces enough electricity to run nav lights as I do sail at night in a busy area. I have changed all internal and nav lights for led bulbs or new lamps. If you need pictures let me know.
Df 800 cruising
