After a year or more, the fresh water tank and hoses will start to grow certain organisms and it is a good idea to "shock" the system with chlorine once per year for Spring commissioning. Here's what I did to clean my DF-1200 tank.
1) Remove the screen from the water pressure pump, and replace the normal pressure output water hose with a short (2-3 ft) 1/2" ID hose to run the water into the engine bilge. (Alternatively a longer section of hose could be run directly overboard).
2) Empty the tank by turning on the fresh water pressure pump.
3) Remove the tank level sender and look in with a flashlight -- you will likely see "growth" particles in the remaining water.
4) Suction out the remaining water and "growth" particles with a shop vacuum (to fit inside the sender hole, I used duct-tape to adapt a 3-ft. 1-1/4" OD plastic hose to my shop vacuum hose)
5) Refill tank and repeat until you can't see any more particles floating around in the tank.
6) Replace filter screen on the pressure pump, and then reconnect your normal output hose. Confirm your water works again.
7) Pour 16 oz. (2 cups) of Clorox (laundry) Bleach into the water tank, which is the right amount for 35 gallons capacity. Replace the water level sender.
8) Fill tank. Run water through each faucet until you smell the strong chlorine smell. Let the chlorine sit in the tank and water lines for 8 - 12 hours but not longer than 24 hours (it's corrosive). That will kill everything that grows.
9) Run all the chlorinated water out and refill tank with fresh water, then run out the lines again to get rid of the chlorine in the lines.
Cleansing fresh water tank
Return to “DF1200 Motor/Equipment/Electrics”
Jump to
- General Dragonfly Trimarans User Forum
- ↳ General
- ↳ HULL issues concerning all DFs
- ↳ Rig/Sail issues concerning all DFs
- ↳ Motor/Equipment/Electrics issues concerning all DFs
- ↳ E V E N T S
- DF25
- ↳ DF25 General Topics
- ↳ DF25 Hull
- ↳ DF25 Rig/Sails
- ↳ DF25 Motor/Equipment/Electrics
- DF800
- ↳ DF800 General Topics
- ↳ DF800 Hull
- ↳ DF800 Rig/Sails
- ↳ DF800 Motor/Equipment/Electrics
- DF28
- ↳ DF28 General Topics
- ↳ DF28 Hull
- ↳ DF28 Rig/Sails
- ↳ DF28 Motor/Equipment/Electrics
- DF920
- ↳ DF920 General Topics
- ↳ DF920 Hull
- ↳ DF920 Rig/Sails
- ↳ DF920 Motor/Equipment/Electrics
- DF1000
- ↳ DF1000 General Topics
- ↳ DF1000 Hull
- ↳ DF1000 Rig/Sails
- ↳ DF1000 Motor/Equipment/Electrics
- DF32
- ↳ DF32 General Topics
- ↳ DF32 Hull
- ↳ DF32 Rig/Sails
- ↳ DF32 Motor/Equipment/Electrics
- DF35
- ↳ DF35 General Topics
- ↳ DF35 Hull
- ↳ DF35 Rig/Sails
- ↳ DF35 Motor/Equipment/Electrics
- DF36
- ↳ DF36 General Topics
- ↳ DF36 Hull
- ↳ DF36 Rigg/ Sails
- ↳ DF36 Motor/ Equipment/ Electronics
- DF1200
- ↳ DF1200 General Topics
- ↳ DF1200 Hull
- ↳ DF1200 Rig/Sails
- ↳ DF1200 Motor/Equipment/Electrics
- DF40
- ↳ DF40 General Topics
- ↳ DF40 Hull
- ↳ DF40 Rig/Sails
- ↳ DF40 Motor/Equipment/Electrics
