I would like to purchase a DF- but no info or boats found here in Brazil.
What is the best place on the Forum to ask basic questions? Thanks.
New Member
Awright, two simple ones? The Plan:penryj wrote:Hi Bob, This is a great place to get the unbiased view. Keep the questions rolling in!
By your reference to "spartan singlehanding" I assume you are planning on doing this single or (perhaps part-time) as a couple? I'll base my answers on that assumption...Awright, two simple ones? The Plan:
Buy a used boat (probably Europe), coastal cruise Europe and canals for a year or so. Then, at the ideal time of year, resell. Questions>>>
#1. MODEL (USED):
Greatest availability: 920, 1000, 35 or 1200?
Greatest demand vs. availability: 920, 1000, 35 or 1200?
BEST LIVEABOARD &/OR EXTENDED CRUISE:
DF 35 or DF 1200, or equally good?
DF 1000?
DF 920 cramped, even for spartan singlehanding?
Looking forward to opinions, thanks.
Bob
Thanks very much, Larry. For live aboard & cruising, I am sure you're right. Whether singlehanded/couple, or not (yes, your assumption IS correct), a larger boat clearly avoids the wear & tear of "camping".Double Horizon wrote::By your reference to "spartan singlehanding" I assume you are planning on doing this single or (perhaps part-time) as a couple? I'll base my answers on that assumption...Awright, two simple ones? The Plan:
#1. MODEL (USED):
DF 1000?
Bob
I'll ignore #1 because that's price-sensitive and the availability fluctuates at any particular time by location and model. Obviously there are more smaller boats sold than larger more expensive ones.
3) The ideal time of year to sell is Winter or Spring, but it really doesn't seem to make much difference in demand. It's all about winter storage and insurance carrying cost.
The quick answer is to buy a 35 if that is your only criteria, or 1200 if you can afford it. There will be more potential buyers for a 35, judging by number of sales of the new boats.Bob in Brazil wrote:Thanks very much, Larry. For live aboard & cruising, I am sure you're right. Whether singlehanded/couple, or not (yes, your assumption IS correct), a larger boat clearly avoids the wear & tear of "camping".
But I should have been clearer>> My post was meant to be about "resale"- an issue sometimes forgotten in the joy of purchase. For the sake of discussion, let's say you were to buy the best 2-6 year old boat you could find- to avoid the usual (but not always!) new boat depreciation....
And let's say your ONLY consideration was an eventual, quick resale with the lowest possible (%) depreciation a year or two down the line. At the moment, which of the three models mentioned would you choose? 1000, 35 or 1200?
Although "resale" is only one (1) issue, I very much hope this discussion helps others think through the financial implications of purchase of their next boat. But in case it is not useful to others, I'll be sure to get in touch directly.
Thanks!
Bob
