mast raising system and procedure
Posted: Fri 04 Mar 11, 19:37
I store my 920 on a trailer in my backyard and pay a boat yard to step the mast up/down with a crane. This has become too expensive. I would like to do it myself. I have all the cables/blocks from Quorning, and I know the procedure. However, to properly support the tip of the mast and move it from trailering position to raising position I would need 2 very tall ladders (4 m) and 3 people. The mast also has to be rotated so the diamond stays face down during stepping and up during trailering.
I want to make this procedure easier and looking for suggestions and/or sketches on how to do it. I know there are a few 920 owners who trailer their boats to cruising destinations and raise the mast themselves. I also read that Arne uses some kind of custom-built set-up to raise the mast.
Ideally, I would like to build something that attaches either to the trailer or to the car's hitch to support the mast while is is positioned for raising or trailering.
I would appreciate suggestions/sketches/description on how Arne and others do this. A detailed step-by-step instructions on who does what/where/when during the mast raising process would be extremely helpful.
(Note: I have a custom trailer and do not use a yard trolley from Quorning. This means that the tip of the mast is about 60-70 cm's higher than on a factory trolley.)
George
George
