Capsize
Posted: Sat 02 Jul 11, 13:27
International Dragonfly Trimarans User Forum
https://forum.dragonfly-trimarans.org/
Unfortunately there will be many more such events, because racers will need to take chances and carry enough sail to be on "the edge" or they will not be competitive.Slowhand wrote:Hi
Here is a sequence of pictures from the capsize - gives some better data for a qualified discussion on how to avoid this kind of event.
http://www.cowesonline.com/d/Round%20th ... %20Lge.mov
It looks like the 28 was built to squeeze under 10 meters when folded. At least in Italy you don't need to register boats <10m, with tax and other cost implications.Roland wrote:The 28 in design and some construction detail is built to a price - I do not say this in a denegratory fashion at all - this is plainly instrumental in the price difference as new. Put another way, some of the construction detail of the 920 has to bear significant cost.
ISCHNURA is 920 Hybrid ie she has an Extreme hull with a standard rig.
Also a good pic of the conditions in this race:There is an interesting sequence of photos of a Dragonfly 28 capsizing in this
years Round the Island Race in England at:
http://www.cowesonline.com/zonexml/story?story_id=11289
Type of boat is irrelevant, as all trimarans can capsize, and there are also
photos of capsized F-boats around, including on my website. However, seeing the
full sequence like this does have some good lessons for all trimarans.
The first is that capsizing can happen more frequently while racing, and any
cruising sailor sailing in such conditions with a spinnaker up is just ASKING
for trouble. So if you want to stay on your feet then reduce sail to suit the
conditions! The boat will not look after you when being sailed like this - you
have to look after it, and be ready to relieve the pressure when needed.
However, the photo sequence does show a number of factors, one being the problem
of having float bows with vertical join flanges along the gunwale. These mean
the submerged bow can act like a water scoop, making it harder for it to spring
back up again. As the sequence starts, it looks like boat is tripping over the
float bow, and it is always far better (and safer) to have well rounded deck
edges on float bows.
Then the spinnaker is released, but the boat is now being slewed around and held
down by the mainsail, which cannot be released downwind. Demonstrates the
hazards of running off the wind with a roachy squaretop main, even if reefed -
better to get it down as much as possible, or even fully down. If the worst
happens, then be well aware that there's NO chance of relieving mainsail
pressure, which is likely being pressed against the rigging, and this may be
what puts the boat over.
However, in this case, as boat continues to heel, the pressure from the main
does ease, due to the very high heel angle, to where main is being sheltered by
the nets and actually backwinded. But then it looks like the wingnet windage
takes over, to eventually put boat right over, even though main is no longer a
factor.
Wingnets must thus always be of open mesh to let the air through, and anyone
with close mesh cat style tramps may want to take a close look at this and
reconsider their options. I have always strongly recommended against the use of
close weave nets, and will never use them myself.
The capsize sequence is actually a good example of how a submersible tri can go
over, with main hull staying in the water, which usually makes them very hard to
capsize as they can spring back (self right) up just like a mono. One one early
TRAMP the mast had hit the water, two of the three crew bailed out, but the boat
(with open weave wing nets) then righted itself.
Too much weight aft may be another factor, as the D28 does have a very long
cabin, which ends just in front of the aft beams, with a relatively short
cockpit at the aft end. I always prefer to have the cabin ending further
forward, so as to allow at least two to sit side by side in front of the aft
beam. Less interior room, but I think the boat is better balanced.
However, I think the wing nets were the main problem on this occasion. Larger
floats or a lighter boat may have been better, but then whole boat would have
been much higher in the air (flying main hull), and exposing two wing nets to
the air. Capsize may have then been more likely, but larger floats 'may' have
also prevented the initial trip.
Nick Wood's F-27 ORIGAMI (2nd on corrected and third fastest) did particularly
well in this race for a 27 year old design, as did Peter Newland's F-9R (second
fastest). Results can be seen at:
Multihull Mocra Results: http://www.roundtheisland.org.uk/web/co ... &submit=Go
(Click on the boat name in this list to see the boat details)
While a photo of Nick Wood's F-27 in the thick of it can be seen at:
http://www.f-boat.com/pages/News3/RoundIsland2011.html
Ian Farrier
Farrier Marine (NZ) Ltd
Farrier Marine, Inc
