On our 920, it appears that a step was missed when assembling. There is a pulley on each side of the mast that I think the reefing lines were supposed to go through. Is there a way to fix this without removing the sails and the boom and starting over? The lines now take 2 people to pull through the mast each time a reef is needed.
The manual says to tie shocks after reefing. My sail has holes to put lines through, but no lines - what do people find useful here - cotton lines to tie, some sort of bungee set up?
Addendum
I have the 4 blocks in place as specified. The part I think I'm missing is on the mast - after the reefing line comes out of the mast, it is currently going directly to the block on the sail. I see a pulley - maybe it's called a cheek block? on the mast above where the line comes out of the mast. I don't know what it's for, so I'm thinking it's for the reefing line.
