230 Volt fuse box
F.Matthies
- Your Country: Germany
230 Volt fuse box
I had a power failure in my 230 Volt electric system. In my owners manual is no description about the fuse box. After long search in the bow near the shorepower plug, I found it finally under the cockpit on the starboard side. To reach it you have to remove the drawer below the cockpit bottom from inside the cabin. Maybe this is a help for someone with a similiar problem.
F. Matthies DF 800SW
