I have a DF800 mk2 (fixed beams)
Mast is hold by a shroud in the middle of the hama and a preventer backstay on the rear of the hama.
With good wind and rough sea (Force 5), the traction force of the preventer backstay is high, while the structure of the boat is flexing, submitting the link between hama and beam to high stress. Relative movement are quite noticable. It is difficult to increase the clamping force of the bolt fixing the beam to the central high enough to avoid small movement. Noisy.
To remove some of the load I am thinking to hold the preventer backstay directly on the back side of the central hull.
Did someone already try it?
Best location to install the chainplate?
Use of a synthetic lashing at the mast end to avoid dammaging the aluminium with shackle?
Preventer backstay fit to the central hull instead hama
Jump to
- General Dragonfly Trimarans User Forum
- ↳ General
- ↳ HULL issues concerning all DFs
- ↳ Rig/Sail issues concerning all DFs
- ↳ Motor/Equipment/Electrics issues concerning all DFs
- ↳ E V E N T S
- DF25
- ↳ DF25 General Topics
- ↳ DF25 Hull
- ↳ DF25 Rig/Sails
- ↳ DF25 Motor/Equipment/Electrics
- DF800
- ↳ DF800 General Topics
- ↳ DF800 Hull
- ↳ DF800 Rig/Sails
- ↳ DF800 Motor/Equipment/Electrics
- DF28
- ↳ DF28 General Topics
- ↳ DF28 Hull
- ↳ DF28 Rig/Sails
- ↳ DF28 Motor/Equipment/Electrics
- DF920
- ↳ DF920 General Topics
- ↳ DF920 Hull
- ↳ DF920 Rig/Sails
- ↳ DF920 Motor/Equipment/Electrics
- DF1000
- ↳ DF1000 General Topics
- ↳ DF1000 Hull
- ↳ DF1000 Rig/Sails
- ↳ DF1000 Motor/Equipment/Electrics
- DF32
- ↳ DF32 General Topics
- ↳ DF32 Hull
- ↳ DF32 Rig/Sails
- ↳ DF32 Motor/Equipment/Electrics
- DF35
- ↳ DF35 General Topics
- ↳ DF35 Hull
- ↳ DF35 Rig/Sails
- ↳ DF35 Motor/Equipment/Electrics
- DF36
- ↳ DF36 General Topics
- ↳ DF36 Hull
- ↳ DF36 Rigg/ Sails
- ↳ DF36 Motor/ Equipment/ Electronics
- DF1200
- ↳ DF1200 General Topics
- ↳ DF1200 Hull
- ↳ DF1200 Rig/Sails
- ↳ DF1200 Motor/Equipment/Electrics
- DF40
- ↳ DF40 General Topics
- ↳ DF40 Hull
- ↳ DF40 Rig/Sails
- ↳ DF40 Motor/Equipment/Electrics
