Been doing some fiberglass repair. Both ama decks were damaged just aft of the forward aka pivot, essentially under the rub-strip. These appear to be old wounds and the starboard one appeared to have been poorly repaired previously.
Questions:
Anyone experienced damage in the same area? Any advice, like the pivot bolt is too tight or not tight enough? Seems obvious to avoid rough water with the amas folded.
What is the 'rub-strip' material? What I mean by rub-strip is the 1/8 inch x 2 inch quarter circle plastic screwed into the ama on which the aka rides while pivoting. It reminds me of ENHE. Anyone replaced this material? What did you use?
Any other advice?
Rub Strip
Jump to
- General Dragonfly Trimarans User Forum
- ↳ General
- ↳ HULL issues concerning all DFs
- ↳ Rig/Sail issues concerning all DFs
- ↳ Motor/Equipment/Electrics issues concerning all DFs
- ↳ E V E N T S
- DF25
- ↳ DF25 General Topics
- ↳ DF25 Hull
- ↳ DF25 Rig/Sails
- ↳ DF25 Motor/Equipment/Electrics
- DF800
- ↳ DF800 General Topics
- ↳ DF800 Hull
- ↳ DF800 Rig/Sails
- ↳ DF800 Motor/Equipment/Electrics
- DF28
- ↳ DF28 General Topics
- ↳ DF28 Hull
- ↳ DF28 Rig/Sails
- ↳ DF28 Motor/Equipment/Electrics
- DF920
- ↳ DF920 General Topics
- ↳ DF920 Hull
- ↳ DF920 Rig/Sails
- ↳ DF920 Motor/Equipment/Electrics
- DF1000
- ↳ DF1000 General Topics
- ↳ DF1000 Hull
- ↳ DF1000 Rig/Sails
- ↳ DF1000 Motor/Equipment/Electrics
- DF32
- ↳ DF32 General Topics
- ↳ DF32 Hull
- ↳ DF32 Rig/Sails
- ↳ DF32 Motor/Equipment/Electrics
- DF35
- ↳ DF35 General Topics
- ↳ DF35 Hull
- ↳ DF35 Rig/Sails
- ↳ DF35 Motor/Equipment/Electrics
- DF36
- ↳ DF36 General Topics
- ↳ DF36 Hull
- ↳ DF36 Rigg/ Sails
- ↳ DF36 Motor/ Equipment/ Electronics
- DF1200
- ↳ DF1200 General Topics
- ↳ DF1200 Hull
- ↳ DF1200 Rig/Sails
- ↳ DF1200 Motor/Equipment/Electrics
- DF40
- ↳ DF40 General Topics
- ↳ DF40 Hull
- ↳ DF40 Rig/Sails
- ↳ DF40 Motor/Equipment/Electrics
