At least on DF 35 it seems pretty easy - lash them to the folding preventer lines that are hooked from the bow to the eyebolts on the outside of front beams, and the other corner to the lifting eye. Just not sure what would be the use. Maybe allows to drop the downwind sail without worrying of missing the main hull deck? Or make spinnaker sheets less likely to drop in the water.
Any other use?
Has anyone rigged bow triangle nets?
