Gas spring lifts for cockpit seats, aft hatch and aft head
If you are in the US you can replace the original equipment gas springs with a stainless model. The source is http://www.mcmaster.com and the item number is 9517T212, select 20 pounds strength. These are expensive but better than the original because they are all-stainless, whereas the original is not.
