I could not find a way to reach this installation from inside and there are no screws outside.
How about left side, do I need to remove the fridge to get there?
I have not yet made this task because my sheaves are not totally broken, this seems to be quite a big and difficult job and I am still able to operate the SwingWing system. I should finish this task, because I know some day the sheaves will broke into pieces.parkhouse wrote:Both out line sheaves in the coaming double blocks (i.e. where the lines are directed to the winch) are cracked and partly broken. I asked Quorning for advice and this is their reply:-
"The double sheave box is beefed up to a slightly bigger size from 10mm
sheaves to 12mm.
You need to cut or file the holes a bit bigger for the new model which
also is more durable.
One double sheave box costs 65 euro +VAT and shipping."
Mika - how did you end up solving your broken sheaves problem?
Mike Paterson, Champus
Why would one even stock/install an inferior block for such a hard to replace installation? For a EUR10 savings?The price for these blocs is EUR 85.- each excl VAT. We have a stronger version which cost EUR 95.- each excl VAT – we have these on stock.
