Wet/Dry Lockers
Wet/Dry Lockers
Which lockers on the boat should be dry, and why will be wet?
Christine
Christine
All lockers should be dry. However one of my amas is wet. The hatch leaks. But I use it for fenders, rops, swim ladder and other stuff that usually is wet.
When packing for a tour with a DF800 - I got the advice from the previous owner - pack in two bags. One bag with the stuff you need today, and one spare bag with the stuff for tomorrrow. Put the tomorrow bags in the amas.
Secondly I use waterproof bags. Water is always close.
It is most likely to be the seals on the hatch handles, or rather the o-rings assuming the wet area is the storage area and its not water coming up through the inspection hatch in the bulkhead below!
The o-rings sealing the handles fail. Spares for the moonlight hatches in the
UK is Houdini: www.houdini-marine.co.uk
Found the problem
Solved the problem a year ago. It was not the hatch handles – it was a crack between the hull sides of the ama. That crack has been there since I bought the boat. It's repaired now. So now the two amas are dry. However, it has the advantage that I had to mount a hatch in the bottom of the storage compartment. And then I got a basement! Perfect for two bags of dirty laundry or fenders that are not used very often. Storage is always usefull. Now I got basements in both amas. It is actually a good idea – even if there is problem with your ama – make an extra hatchway in the bottom of the storage compartment. And you got more space.
