mast rigging
mast rigging
which is the tension of diamonds and shrouds
mast rigging
e need to trim a mast can anyone help me ?
mast rigging
Here are specs as supplied to me by Quornings for 920 tourer mast. I quote:"rig tension on DF920 touring/cruising is measured with american gauge Loos Co model PT3.
Side diamonds stays:21
forward jumper: 24
The inner diagonal diamond stay is 5mm cable is only set by hand + 2 full turns. The mast needs a curve forward a minimum of 5 and maximum 7 cm mrasured from top to the foot"
forward jumper: 24
Andrew H.
sjschweitzer815
- Your Country: USA, Racine, WI
Mast rigging
Andrew H...mast curves "Forward"?
Re: Mast rigging
meaning the center of the mast is slightly further forward than the mast base and the mast top. Just like most other masts on regular sailboats.sjschweitzer815 wrote:Andrew H...mast curves "Forward"?
