I'm not associated with any of these companies, just thought you might like to know.
Home Depot is selling Philips brand 12 volt LED. Two GU4/MRII indoor/outdoor flood models are available in my local store, 100 lumen @ 3 watts ($19.99) and 140 lumen @ 3.5 watts ($22.99). According to the packaging, it takes 20 watts for a halogen to make 100 lumen.
Both these models fit into the eyeball light aboard my DF 1000 (saloon and v-berth) once the metal reflector was removed. A simple turn of the fixture's outer ring drops the ring and the reflector. The reflector can then be separated from the ring. I thought the lights looked better with the ring than without.
They seem to work with the dimmer system in the saloon.
The 140 lumen bulb is a significant upgrade to the reading lights in the v-berth...and no heat!
West Marine is selling a GU4/MRII flood from DR LED for $29.00. I've no data regarding the lumen output or watts required.
LED Lights
Return to “Motor/Equipment/Electrics issues concerning all DFs”
Jump to
- General Dragonfly Trimarans User Forum
- ↳ General
- ↳ HULL issues concerning all DFs
- ↳ Rig/Sail issues concerning all DFs
- ↳ Motor/Equipment/Electrics issues concerning all DFs
- ↳ E V E N T S
- DF25
- ↳ DF25 General Topics
- ↳ DF25 Hull
- ↳ DF25 Rig/Sails
- ↳ DF25 Motor/Equipment/Electrics
- DF800
- ↳ DF800 General Topics
- ↳ DF800 Hull
- ↳ DF800 Rig/Sails
- ↳ DF800 Motor/Equipment/Electrics
- DF28
- ↳ DF28 General Topics
- ↳ DF28 Hull
- ↳ DF28 Rig/Sails
- ↳ DF28 Motor/Equipment/Electrics
- DF920
- ↳ DF920 General Topics
- ↳ DF920 Hull
- ↳ DF920 Rig/Sails
- ↳ DF920 Motor/Equipment/Electrics
- DF1000
- ↳ DF1000 General Topics
- ↳ DF1000 Hull
- ↳ DF1000 Rig/Sails
- ↳ DF1000 Motor/Equipment/Electrics
- DF32
- ↳ DF32 General Topics
- ↳ DF32 Hull
- ↳ DF32 Rig/Sails
- ↳ DF32 Motor/Equipment/Electrics
- DF35
- ↳ DF35 General Topics
- ↳ DF35 Hull
- ↳ DF35 Rig/Sails
- ↳ DF35 Motor/Equipment/Electrics
- DF36
- ↳ DF36 General Topics
- ↳ DF36 Hull
- ↳ DF36 Rigg/ Sails
- ↳ DF36 Motor/ Equipment/ Electronics
- DF1200
- ↳ DF1200 General Topics
- ↳ DF1200 Hull
- ↳ DF1200 Rig/Sails
- ↳ DF1200 Motor/Equipment/Electrics
- DF40
- ↳ DF40 General Topics
- ↳ DF40 Hull
- ↳ DF40 Rig/Sails
- ↳ DF40 Motor/Equipment/Electrics
