Ama rubbing strake/trim
andycrawford
Your Country: United Kingdom, Poole
Post by andycrawford »
Does anyone know where you can source the grey rubbing plastic/rubber rubbing strake which is fitted over the top of the hull/deck joint (upstand) around the top of each of the ama's. My boat is a 920 but I am sure it is fitted on most of the other models. I have tried to source through the U.K dealer but not getting anywhere quickly. I could go to the yard but it may be a lot quicker if I could source from the manufacturer or a specialist supplier. Hope someone can help
andycrawford
Ama rubbing strake
i can now answer my own question! The best place to get the rubbing strake is from the factory, not too expensive EU 10/m + shipping. Sold by the metre or for an entire hull. Quorning source the material from a manufacturer in Denmark, hence it seems best to go direct to them.
What is the factory name? Can you provide contact information?
andycrawford
Ama rubbing strake
sorry if not clear, best to get strake from Quorning
